I've created a short video (.a3s) of a large Inventor file (.iasm), and want to create an .mov.
I try to publish the movie locally, and nothing happens. I've closed & reopened Showcase, and IV isn't open at all, and I've also tried to publish in different file formats, and it hasn't made a difference yet.
I've included a screen shot of my settings.
Any suggestions?
Post script:
I can publish jpgs/images.
When you have your Showcase (a3s) file open and you press (T), do you get any saved "shots"? You need to create your save shots and "to-from's" in order to publish a movie.
Also check that you have all the latest SP's installed, ShowCase 2013 should be on SP3
try opening the "watch" sample shipped with ShowCase and try publishing a movie.
If you have shots and are not part of the Storyboard then it will not work. So you can select the option Create movie of All Shots Together. But the test with the Watch is the best start.
