Inventor Forum
Sheet metal bending
2 REPLIES 2
418 Views, 2 Replies
Sheet metal bending
I have a piece of sheet metal that I am bending at 180 degrees with enough radius for the bend. The final bent piece shows up off to the side of the origin and not in line with any of the base planes. The original flat piece is fully constrained to the origin. How can I fix it so that the center of the bent piece is in line with a base plane?
Tags (1)
2 REPLIES 2
blair
If it's possible to post the part, I can take a look at it on the weekend. I am currently at AU
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mpatchus
Instead of using the BEND tool, why not create the part using a CONTOUR FLANGE.
This gives you more control over the orientation of the part in relation to the origin planes.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
