Solved by blair. Go to Solution.
Solved by Cadmanto. Go to Solution.
Jamie,
I have not worked much with the sheet metal, but as far as the BOM goes, what my suggestion would be is to create an ipart for the LH and RH versions. Then in the BOM they can have two distinctly different part numbers. Not to mention in the assembly these iparts are used, the assemblies can be iassemblies with each member of the iassembly having its own column in the BOM for quantities. This method for me has worked and is makes things fairly clear on the drawing. Hope this helps.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
We create the LH version from scratch using the Sheet-Metal module in Inventor, then Derive the RH version using the Mirror function to get the RH part. When we do our drawing, we only draw the LH item with notes on the drawing detailing it's the LH and view. Notes on the flat lay-out and bend table are also included. We have never had a problem from our outside suppliers with this method, some actually prefer it as it reduces paperwork.
Let us know how the iparts and iassemblies go for you. I know there are youtube videos that could assist you.
As far as your other threads go, I am not an iLogic guru at all. Sorry, or I would be glad to help you out. What I can suggest is if you do not get much of a response from this forum you can try posting them in the customization forum. That is were a lot of that kind of stuff is listed.
