Inventor Forum
Sheet metal/Flat pattern screews up coordinates.
5 REPLIES 5
ENRAD
557 Views, 5 Replies
Why is it, when I go to Flat Pattern/export to DXF that everything ends up upside down.
I have part where it is important that the correct side is faced upp, (brusched steel).
When i Export it to dxf, it is upside down, and the bruched facefacing down.
5 REPLIES 5
JDMather
in reply to: ENRAD
You can flip before exporting.
Attach your file here.
ENRAD
in reply to: JDMather
Ok, found that, but why cant it be correct from the beginning?
Curtis_Waguespack
in reply to: ENRAD
Hi ENRAD,
As JDMather mentioned you can adjust the flat pattern orientation before exporting it as described at this link:
http://inventortrenches.blogspot.com/2011/05/edit-flat-pattern-orientation.html
I hope this helps.
Curtis
ENRAD
in reply to: Curtis_Waguespack
Yes I understand that, But, if I have say 300 parts to export, thats nearly 1000 extra mouse-clicks to do, so why cant Inventor do it correct in the first place.
drlamb
in reply to: ENRAD
Pick your face side before you create the flat pattern. You may want to rotate your flat pattern after, but at least your "good" side will be facing you.
Donald L.
Inventor Product Design Suite 2016
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
16 Gb
AMD Radeon HD7950 3Gb
