Willy,
Generally speaking, Inventor does not support unfolding spline face in sheet
metal.
Johnson Shiue
Test Engineer
wrote in message news:4832547@discussion.autodesk.com...
Creating "contour flange" sheet metal part with a sketch containing a
spline-section is working fine, accept the flat pattern creation. Should it
be possible to use a spline in the contour-flange function, where can I
find tips & tricks about this, has someone any suggestions? Thanx in
advance.
Willy Driessen
