Inventor Forum
Sheet Metal Hopper
11 REPLIES 11
Message 1 of 12
1647 Views, 11 Replies
Sheet Metal Hopper
Greetings,
I am struggling to create the attached PDF drawing with Inventor 2013. In the attached IPT I created the right-hand PDF view and I am simply at a loss on what to do next. Any help on creating this would be appreciated.
Thanks!
11 REPLIES 11
Message 2 of 12
I cannot show you my steps, since I'm on a 2015 version.
I would make the cut so it is 9.8 in the bottom. With that I would take the square hole as a cut as well.
After that, i would make one flange feature containing two flanges
Message 3 of 12
Hi yannicknielsen, The problem that I was having was the actual length of angled line 🙂 That said, if you'd like, take a look at my flange height extents (63.78). The only way that I could get this length was by using the Old Method option. Other than me being old, I don't know what Old Method means. A mentoring question - if you were modeling this component, would you have started with the front view or right view like I did? Thanks!
Message 4 of 12
blair
I would start with the flat lay-out, then fold the top flange and use the flange tool for the two side flanges. One may need to adjust the overall height as the drawn flat layout could be slightly off due to the k-factor (bend allowance).
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 12
IgorMir
Hi rsmodeler
The attached file should give you some ideas. It is in IV2010 format.
Igor.
@Anonymous wrote:
Greetings,
Thanks!
Web: www.meqc.com.au
Message 6 of 12
in reply to: IgorMir
Everyone, thanks for your response! Igor, The part that you created was a great learning experience! I have a question. Would you be so kind and look at the attached JPG and tell me if it's possible to fill in the area between the top and side flanges. Thanks!
Message 7 of 12
IgorMir
Hi Rcmodeler.
Glad to be of help. Here is a part which should give you an idea how to fill that gap.
Cheers,
Igor.
Message 8 of 12
WHolzwarth
IMO, there's no exact solution possible for this task, because of collisions in the unfolded part.
See attached an approximation.
Walter
Walter Holzwarth
Message 9 of 12
in reply to: WHolzwarth
Greetings, Can someone show me in the attached 2013 IPT or explain how to remove material shown in the attached JPG? Thanks,
Message 10 of 12
IgorMir
Say, do you do it for a living or do you try to learn the software on your own?
Cheers,
Igor.
Message 11 of 12
Hi Igor,
I am not a fulltime engineer / designer / drafter. A couple of years ago I took most of the inventor courses through my local Valued Added Reseller using Autodesk Training Material 🙂 I smile because the sheet metal exercises were pretty simplistic. Based on my background I do some part-time inventor work and I also enjoy using the software as a hobbyist. The part that I posted has tripped me up a couple of times along the way. In my last post I thought I could do a simple cut to lop off unecessay material. Anyway, I will be revisiting the part after a good night sleep 🙂
Message 12 of 12
IgorMir
Thanks for sharing. As for the removing/adding material to the flange - it would be easier to create a Face instead of a Flange. The Flanges are somewhat limited to straight corners only.
Cheers,
Igor.
