Inventor Forum
Sheet Metal Cylinder
6 REPLIES 6
560 Views, 6 Replies
I am having trouble trying to figure out how to roll up a sheet metal piece into a full, 360 degree cylinder. Could anyone instruct me, or point me to the proper online tutorial.
Thank you,
Brad
6 REPLIES 6
jmartzig
brad, see "cylindrical tube in sheet metal to flat pattern" post on nov 14th 2002. -Joe
Thanks Joe, but I guess I needed to clarify a bit more. I need to do the reverse of your situation. I have a flat pattern that already has cutouts, which needs to be rolled into a cylinder. Can this be done in inventor? Brad
See CF for a way to cheat.  You can use the
fold command to curl a flat piece of metal.  I just made up some radii so
it's not a 360 cyl but you get the idea...
Maybe some of the sheetmetal masters have a better
idea...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Brad
Thanks, Sean. I checked out your example and was able to duplicate it. Brad.
Sorry Sean,
would like to see your example. I am new to this format. What is CF and how do I get there.
Gil Peel
If you are new to the NG I would suggest reading
the FAQ I post weekly.  Search for *** and you'll find it.  It has
lots of other good info.
Cheers!
Sean Dotson, PE
...sleep is for the
weak..
Sorry
Sean,
Gil Peel
