There are a couple of ways to "draw" on a curved surface.
In Sheetmetal, you can use the "Project" tool (flyout) to project the
flat pattern sketch of the part. During the extrude/cut operation,
select "cut across bend".
In a "normal" part, after creating a sketch, you can use the emboss
feature to "wrap" the sketch and cut or extrude it along/over a curved
face.
Another method would be to use the replace face tool by incorporating a
surface that would define the new "extrude to" face.
QBZ
"Gary_M" wrote in message
news:8562D9695D11E087B76A1298062EA5D3@in.WebX.maYIadrTaRb...
> Yes, thats what I want. I wonder if this will ever be possible with
> Inventor? We normally do Rails in Ideas, but they do not a have sheet
metal
> section so it is made as a swept profile. That group was hoping to use
IV a
> demonstartion tool and curving that rail was key. Inside the rail are
some
> teeth (to be cut later) but when they try to create the teeth they
look a
> little chopy. Isn't there a way to draw on a curved surface?
