Inventor Forum
Sheet Metal Cone
9 REPLIES 9
Message 1 of 10
mattBA
1503 Views, 9 Replies
Sheet Metal Cone
Is it possible to make a cone with sheet metal that can be unfolded?
9 REPLIES 9
Message 2 of 10
in reply to: mattBA
Yes. Post what you have and the version used.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 3 of 10
mattBA
in reply to: mattBA
I have attached a AI 2009 part file of what I want flattened. I thought I would be able to use contour flange but wasn't able make it work. What I ended up doing was using extrude and then shelling it but when I pressed flat pattern it gave an error about the thickness. Somehow I have to use face to get the sheet metal properties. I just don't know how.
Any advice would be nice.
Message 4 of 10
mcgyvr
in reply to: mattBA
Press the "sheet metal defaults" button, (uncheck use thickness from rule if its checked) set thickness to .0478 and click okay.
Then select (highlight) the inside surface of your cone and press the flat pattern button..
Message 5 of 10
JDMather
in reply to: mattBA
I noticed that Sketch1 is placed at the origin but not constrained to the origin. If you would set Inventor up correctly it would have been automatically constrained.
Shell does not result in the correct sheet metal flat pattern. Although it will flatten if set the thickness correctly - go to wireframe mode and examine top and bottom of flat pattern. You will see edges are not cut perpendicular to flat.
Sketch2 is not needed - you could have used the YZ plane to Sculpt or Split the part.
In fact you could have simply sketched an angled line and revolved a surface 180°.
Then Thicken to get the correct part.
Message 6 of 10
jcbyrne2
in reply to: mattBA
when you shelled the solid the top and bottom edges were not square to the sides. Inventor may have had a problem with this. A slanted line rotated around an axis as a surface and thickened might be tried . A tilted rectangle using three point rec and rotated around an axis may also work. Highlighting one surface before flatten command will sometimes help.
Message 7 of 10
in reply to: mattBA
Here is the proper SM part. Note that I did not change or
repair your geometry. You need to follow JD's advice on fulluy dimensioning -
contraining - anchoring all geometry in you sketches - every time. This is just
good practice to avoid downstream editing issues.
Go through the steps in the browser with the eop to see how I
did it....
Expert
Expert.
PcCillin AV
XP
Message 8 of 10
in reply to: mattBA
No need. See my last post.
Expert
Expert.
PcCillin AV
XP
Message 9 of 10
idragonb
in reply to: mattBA
I understand this an old listing, but I did a revolution and rip which reported a problem - just wanted to point out that you can solve this by increasing distance from center and then you can rip...
Flow state:
Maximum challenge with maximum skills.
Message 10 of 10
JDMather
in reply to: idragonb
I don't understand the problem or solution - can you attach the ipt file here?
