I am not able to see the model in shaded view with edges in dynamic simulation environment (Autodesk Inventor 2012). How can I enable this facility here. Please help me in this regard.
Solved by ravikmb5. Go to Solution.
More information is needed.
Post screen shot.
Post dataset.
When you go into DS Inventor automatically switches to Shaded rather than Shaded with Edges view style ( am major irritation to me). Have you switched it back to Shaded with Edges?
The CADWhisperer YouTube Channel
Yes I tried to switch back to shaded with edges but this tab is disabled. See the screen shot.
shaded with edges is working here
which version is it
Thanks for your sincere response, but I am using Inventor 2012 version, so the problem stands.
Have you installed all Service Packs for 2012?
Sorry Inventor 2012 doesn't allow u to change the visual styles in Dynamic Simulation environment
only inventor 2013 and later versions has this option
