I have the same thing happening to me. I have 5 shaded parts all closely
fitted, kind of an exploded view, and each part had blocks around the edges
that overlap and on screen you couldn't see them, when it prints, it prints
overlapped white block edges around the edge of each part where it gets too
close to the other parts. I then said to myself, "Self" why didn't you use
the ipn part of inventor, it would probably handle this better. It was too
late, maybe next time.
Jerry
"John Tinelli" wrote in message
news:81C045F9F073C41EA65454D0C036D4D6@in.WebX.maYIadrTaRb...
> Tracy,
> I am not sure why, but I had a similar problem it had to do with memory in
> the printer. Only half of a shaded view would print as shaded, the other
> half was hidden lines. When more memory was added, problem went away.
> Does it appear blocked out on your screen or just on the paper print?
> If its on the screen that way, its related to your video card.
> If its only the paper print, its printer memory / driver issues.
> Did you try reloading the printer driver? Or getting an updated one?
> John T
> "Tracy Yoho" wrote in message
> news:B3599FB6017343249647B346AD0B54B6@in.WebX.maYIadrTaRb...
> > When I place a shaded view in an .idw I have to be careful that the view
> > doesn't overlap any other views or it will block them from printing.
It's
> > like the background of the shaded view is set to white although it
> appears
> > transparent on the screen. This isn't a big problem but I do a lot of A
> size
> > drawings and real-estate is tight. Is there a setting I'm missing to
make
> > the background print transparent?
