I just installed my autodesk inventor professional 2015 today. How do i know which service packs need to be installed and which already are? It be really helpful if someone could help me out.
Thanks!
Solved by James_Willo. Go to Solution.
Solved by karthur1. Go to Solution.
and later, if there is available service pack or update, Autodesk Application Manager(check the Toolbar of your computer, it should be running) will notice you automatiaclly and you can download and install them in it.
You say "and later" because its NOT working now.
I think someone said they hope to have that fixed by SP2 (around september timeframe I thought)
it works for service pack already, but there is no any released Inventor 2015 SP so far, so, Application Manager cannot detect it.
as for update(Inventor 2015 update1 was released), yes, I think after SP2, both SP and update could be detect by Application Manager(it will upgrade itself) once any of thme was released
We get the SP's from the Autodesk Subscription webpage nowadays. 3 releases back from the current version is as far as they go. Unless someone has a 2015 sp in an archive folder somewhere they would share, you might be out of luck there.
They changed this recently. We only support 3 years back, but they now also only give out RTM and the latest service pack through Manage.autodesk.com
If you need any specific service packs, please raise a support ticket and we'll do our best to provide it.
I think you might be able to do this through https://manage.autodesk.com/home and support cases > manage support cases.
Hi! If I recall correctly, supporting current and three releases back is a contractual obligation in the user agreement. Earlier updates are still available upon request. However, they are not made available to download generally.
Unfortunately, 2015 is way too old. I cannot find any install or related updates for the release on our internal servers.
Many thanks!
