Inventor Forum
Select Component Priority no longer shows face/edge preview
2 REPLIES 2
477 Views, 2 Replies
This has happened since I updated to 2012 Professional.  When I want to use the measure tool or add constrains in assembly mode, the face/edge preview does not show up in red under Select Component Priority.  I have to wait for the select other option to come up to see which face I am on.  If I click on the face or edge it will show up but not until I do.  I don't remember changing any settings that would cause this.  Is this happening to anyone else? I could have the select other option delay set to zero or I could change it to another selection priority but I don't remember having to do that before.
2 REPLIES 2
xiaoyan.qi
you can try to change the Color scheme to "Millennium" and check whether it works(see attached picture for details)
Mick
in reply to: xiaoyan.qi
Thanks Mick.  Even though your suggestion didn't solve the problem it brought me to the colors tab under application options, where I found that somehow the "Enable Prehighlight" box was unchecked.  Didn't know that was even an option.
Dan
