Inventor Forum
Section view won't work w/ view reps.
1 REPLY 1
503 Views, 1 Reply
I have a model that I want to show a top view that is cropped and then show a section cut from that view.  I need to shut off the ceiling in the top view but I want to show the ceiling in the section view.  I've set up view reps of OVHD-ON/OFF.  When I crop the original, do a section cut, and then manually turn off the visibility of the overhead it works fine.  It only sections the area that was cropped and the view shows a sectioned ceiling.  The problem is when I want to set up a view rep for the space.  When I use the view rep then the overhead shows in the section view past the crop line.  What gives?
On the attached picture you'll see what the section view looks like after I manually turn off the OVHD visibility on the left (what I want) and the right shows what happens when I use the view representations..
1 REPLY 1
innovatenate
Do you have the associative box checked for the drawing views? It's the radio box with a chain icon in the top right hand area of Design Views in the Edit View dialogue.
Are you manually a value into the Margins field of the Edit Drawing View > Model State tab?
Another feature that may help is the Tools > Documents Settings > Modeling Tab > Participate in Assembly and Drawing Section option.
Nathan Chandler
Principal Specialist
