Inventor Forum
Section view without hidden features
3 REPLIES 3
403 Views, 3 Replies
When I create a section view in the idw, hidden lines are visible in the cutting part !
How disable these hidden lines and show only the hidden features ?
Thanks.
Greg
3 REPLIES 3
mpatchus
Double click on the  section view and uncheck the inherit properties from base view box.
Then select the HIDDEN LINE REMOVED icon.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Thanks but this procedure disable all hidden features.
I just want disable hidden features for section (with hatching) and keep hidden lines where there are no hatching.
Have you an idea?
mpatchus
Using a break out view, the only method I know would be to manually select the hidden lines and turn their visibility off. (RMB - Visibility).
Inventor 2025 Beta
