There must be something simple I am missing, but I cannot find it.
I have a section line that is missing one of the teminator arrows and the label.
I have checked the styles, tried to edit the style but cannot make the terminator and label visible.
Inventor 2013
Win7 x64
Mon
Mon,
If you RC on the section arrow and click on "Second Arrow", what shows up as your terminator?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Yeah, that looks the same as what I have in the styles.
Did this just start happening? Are others in your department seeing the same thing?
Is this the only drawing you are seeing this with?
I noticed it yesterday, however I was removing the view, so I didn't persue it further.
The original file was created with Inventor 2011, and has been updated with each release.
I just tried a brand new part in a new instance on Inventor, when I sectioned the drawing, I got the same issue.
Are you running the latest service pack?
I got it. When creating the view, I drew the sectionline and then a short segment indicating the direction of the view. When I stopped drawing the "direction" of the view, both terminators and labels were present.
Thanks for your time.
No problem. Glad you found a resolution. It is still a bit odd though. When I create a section view, I just draw the straight section line and select done, then once the view is placed the section arrows show up. Both of them.
What ever works!!
