Inventor General Discussion
Valued Contributor
cdyck
Message 1 of 9 (346 Views)
Section View depth
346 Views, 8 Replies
02-02-2005 08:06 AM
When I try to edit the section view depth my only choice is full. The depth is grayed. Is there a setting to turn on to allow this operation?
*Andrew Faix \(Autodesk\)
Message 2 of 9 (346 Views)
Re: Section View depth
02-02-2005 08:13 AM in reply to: cdyck
Are you selecing "Distance" from the first drop-down list? -- Andrew Faix Product Designer - Inventor Drawing Manager Autodesk "cdyck" wrote in message news:24823401.1107360414035.JavaMail.jive@jiveforum1.autodesk.com... > When I try to edit the section view depth my only choice is full. The > depth is grayed. Is there a setting to turn on to allow this operation?
Valued Contributor
cdyck
Message 3 of 9 (346 Views)
02-02-2005 11:35 AM in reply to: cdyck
When I pick the dropdown box that says "FULL" I am not offered any other choice.
Message 4 of 9 (346 Views)
02-03-2005 06:26 AM in reply to: cdyck
I can't think of any condition that would prevent you from doing this? Is this problem file-specific? Please try creating a new drawing and placing a base view of a different model, create a section view and see if the problem persists. If this is file-specific, please post or send me the dataset (model and drawing). andrew.faix@autodesk.com Thanks, -- Andrew Faix Product Designer - Inventor Drawing Manager Autodesk "cdyck" wrote in message news:28970542.1107372956343.JavaMail.jive@jiveforum2.autodesk.com... > When I pick the dropdown box that says "FULL" I am not offered any other > choice.
Valued Contributor
cdyck
Message 5 of 9 (346 Views)
02-03-2005 08:19 AM in reply to: cdyck
I checked to see if this problem is file specific or project specific. It is neither, it doesn't offer me the option for depth .
By the way I am using Inventor 9 Pro. but this project is not using the Pro icon, so I am assuming it is normal Inventor 9.
Message 6 of 9 (346 Views)
02-03-2005 09:49 AM in reply to: cdyck
Well, you can send me the file and I can check it, but it seems that this problem is local to your machine. Again, there should be no condition that would prevent you from changing from a full section to a user-defined depth. -- Andrew Faix Product Designer - Inventor Drawing Manager Autodesk "cdyck" wrote in message news:4661559.1107447629610.JavaMail.jive@jiveforum2.autodesk.com... >I checked to see if this problem is file specific or project specific. It >is neither, it doesn't offer me the option for depth . > By the way I am using Inventor 9 Pro. but this project is not using the > Pro icon, so I am assuming it is normal Inventor 9.
Member
Nakose1
Message 7 of 9 (252 Views)
04-04-2013 07:59 AM in reply to: cdyck
right click on view, edit section properties.
JDMather
Message 8 of 9 (244 Views)
04-04-2013 08:07 AM in reply to: Nakose1
Hopefully the OP solved this problem 8 years ago.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
Nakose1
Message 9 of 9 (239 Views)
04-04-2013 08:09 AM in reply to: JDMather
Hopefully, but I didn't see an answer so I posted.
Ivan E. Bear, Sr.
Contract Designer I
Matrix PDM Engineering
Phone: 918.624.6238
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
