I just want to know how to save a visual style so I do not have to set it again when I create a new drawing..
It gets really frustrating when you cant see the edges..
Solved by Curtis_Waguespack. Go to Solution.
Hi jurcic,
Go to the Tools tab > Application Options > Display tab and you can choose to use the Application settings rather than the per document setting.
I hope this helps.
Curtis
