Inventor Forum
Save as 3D model to DWF files
4 REPLIES 4
sjalluri
623 Views, 4 Replies
I am not seeing the "Save as to DWF" in my Inventor 2011 save as list.
Please suggest any one what to do.
Sri
4 REPLIES 4
KevinLi-Autodesk
in reply to: sjalluri
Hi Sri,
Thanks for your report !
Firstly please check if Add-In Translator- DWF or Translator- DWFX is loaded or not in Add-In Manager 2011 dialog box, you can go to ribbon Tools > Options panel, click Add-Ins button to launch the dialog box.
Secondly please use Save Copy As command then you should see the DWF file type list, i attach two images for describe.
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
sjalluri
in reply to: KevinLi-Autodesk
Thanks for quick reply.
I would like to inform you that, I used to create with the same procedure. But, I have got the new system (Windows 7 operating syetsem) with in which I can't see this option.
Please see attached screen shots of my Inventor 2011.
Srinivasu.
KevinLi-Autodesk
Hi Sri,
Thanks for your comments !
From you screenshot, seems add in Translator:  DWF and Translator:  DWFX are not loaded, can you try to set them to Startup/Loaded and relaunch your Inventor for double check ?
My inventor 2011 is installed in Win 7 OS and doesn't see your problem.
You can also use Export to DWF command to save to DWF file, see attached image. Do you have this command ?
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Hi All,
I was wondering if there is an iLogic snippet to save an assembly in .dwf format?
Many thanks,
Kris
