When I save as DXF, I have to manually go into options on the save tab and click "default DXF configuration," otherwise it exports the file as a ZIP folder. I can't figure out how to save the configuration so I dont have to manually do that everytime, im sure it something simple, as it usually is..
jletcher is correct, hit the save configuration button then the next time you simply need to call that one up and it will be the same every time.
To recall that saved configuration:
