ADMS 2012 will run with SQL 2005, right? I dont' see anything in the documentation about it and am getting nervous. Can someone please verfy that for me?
SQL 2008 is required.
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=17247402
Loouk under the "Autodesk Data Management Server Requirements" tab.
Steve Walton
I probably should be able to answer this myself, but I must swallow my pride and ask anyway. There is something that I just don't understand. For testing purposes, I have installed the Autodesk Data Management Server Console 2012 on my laptop. It is not a server, does not have SQL 2008 on it and yet it works just fine. It is a Windows 7 Professional 64 bit machine. I can access all of my content center parts from multiple computers. So it begs the question, why do I even need to run ADMS 2012 on a server with SQL 2008?
Local database
By default, the server installer is configured to use a local database. If a compatible local SQL instance named 'AUTODESKVAULT' is detected, the server connects to the existing database. You are prompted to migrate the existing database once the installation is complete. If a local SQL instance named 'AUTODESKVAULT' is not detected or if the local instance is not compatible, then Microsoft SQL Express 2008 SP2 is installed.
from
Why a server with full sql? Performance, database size, or replication across several sites.
Steve Walton
Very helpful. That is what I was thinking as far as the performance and database size. I don't feel like I really see much difference in the performance and I think we are O.K. on the database size. I am very grateful for the documentation links so thanks again.
See
http://www.microsoft.com/sqlserver/en/us/product-info/compare.aspx
1 GB of ram and 10 GB of database. The filestore can be as big as you have disk space, but the database is limited to 10 GB. The database stores all of the links between the files and various user interactions with the files. I think it took 2-3 years for us to go from an empty vault to 4GB of database. we only have 4-5 users so we don't generate lots of transactions.
I would use a dedicated machine, even if its just an old workstation, rather than trying to run ADMS and IV on a production workstation.
Steve Walton
For 2012, I'll be trying to use the Desktop Content Libraries located on a shared server instead of ADMS. We're also five users, and don't use Content Center very much, so I'm hoping that this will be a simpler way to do what we want.
