I am getting runtime error message when I am trying to create a x-section in a assy drawing (see attached).
Any leads for a solution?
thanks,
hi, is this the only drawing you are crashing or is it any drawing that you try to section?
Hi, could you please attach the file you used here? I'll have a try to reproduce it and figure out if it's a drawing related issue.
Evan
Inventor Core Team
Hi ,
If you don't mind, can you send your STEP file to Hongyuan.Li@autodesk.com , we will take a further investigation for you.
Kevin Li
