Inventor Forum
Rule to rename newly placed iLogic assemblies
7 REPLIES 7
Message 1 of 8
daulj
798 Views, 7 Replies
I'm running Invenor 2013 and I'm trying to figure out a way to rename my components from an iLogic assembly when placed in a new assembly.
Right now when I start a new assembly, then place an iLogic component it names everything "Part-01," Part1-01" and so on for all of the variable components.
What I'd like to do is write a rule that when placing my iLogic component it will name it based on the filename of the new assembly that I've created. "Part-New Assmebly," "Part1-New Assembly" and so on.
Has anyone out there done this. I'm looking for some sample code that can make this happen!
7 REPLIES 7
Message 2 of 8
reginaldmb
in reply to: daulj
YES PLEASE,  I am also looking for an answer to this.  Any PRO out there please?
Message 3 of 8
MjDeck
in reply to: reginaldmb
It should be possible to do this with a custom add-in (written in VB or C#). But I don't have any sample code.
Mike Deck
Software Developer
Autodesk, Inc.
Message 4 of 8
reginaldmb
in reply to: daulj
Thank you for the reply! That is quite a pity...hope Autodesk will work on that!
Message 5 of 8
reginaldmb
in reply to: MjDeck
Hi! Do you perhaps know someone who would know how to program the coding for this?
Message 6 of 8
Carthik_Babu
check out this link, hope it will be useful
http://beinginventive.typepad.com/being-inventive/2010/04/replacing-and-renaming-components-in-an-as...
http://beinginventive.typepad.com/files/file-rename-with-inventor-ilogic-2.flv
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
Message 7 of 8
Carthik_Babu
The below link give idea of renaming all component (it meant for renaming solid bodies in a component)
http://inventortrenches.blogspot.in/2012/02/ilogic-to-rename-all-solid-bodies.html
Message 8 of 8
tsreagan
in reply to: Carthik_Babu
Here ya go.
Needs Minimal Modification.
Browser nodes should be named by "Default" for this to show,  untill you add part number or file name code.
T.S.
