I'm running Invenor 2013 and I'm trying to figure out a way to rename my components from an iLogic assembly when placed in a new assembly.
Right now when I start a new assembly, then place an iLogic component it names everything "Part-01," Part1-01" and so on for all of the variable components.
What I'd like to do is write a rule that when placing my iLogic component it will name it based on the filename of the new assembly that I've created. "Part-New Assmebly," "Part1-New Assembly" and so on.
Has anyone out there done this. I'm looking for some sample code that can make this happen!
It should be possible to do this with a custom add-in (written in VB or C#). But I don't have any sample code.
Here ya go.
Needs Minimal Modification.
Browser nodes should be named by "Default" for this to show, untill you add part number or file name code.
T.S.
