Inventor Forum
Rule Error
4 REPLIES 4
ASchlaack
295 Views, 4 Replies
Rule Error
This post is unrelated to the one I just posted about 5 minutes ago, I wrote a rule I've used before and know works but now it's giving me an error... any ideas?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
4 REPLIES 4
ASchlaack
in reply to: ASchlaack
ADDED:
-This rule is inside of an .iam.
-The part I'm trying to control is an iPart but the iPart valiabies have nothing to do with what I'm adjusting now.
-The "d117" is a reference dimension on another part in the .iam.
Aaron Schlaack
wimann
So I imagine you have another rule or something to indicate what d117 is in your assembly right? You might pull it in as a user parameter:
Newd117 = parameter("Part2:1","d117")
Parameter("Part1:1","dnumber") = Newd117
Something like that. With your current code, it's referencing d117 as it exists in the assembly, which with most coincident constraints, may be zero.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
ASchlaack
in reply to: wimann
I don't have another rule... d117 is just a referecnce dimension...
Aaron Schlaack
wimann
If the rule exists in your assembly, then it is referencing d117 from your assembly. d117 probably exists at both the part and assembly level. Which means the rule is trying to push the assembly level d117 to your part instead of the reference dimension your trying to use. My suggestion is the same lol:
Newd117 = Parameter("YourComponent2:1","d117")
Parameter(YourComponent1:1","dwhatever") = Newd117
ilogicvb.updatewhendone = true
EDIT: OR! What might work:
Parameter("YourComponent1:1","dwhatever") = Parameter("YourComponent2:1","d117")
-Will Mann
