Inventor General Discussion
Member
mklassen78
Message 1 of 17 (602 Views)
Rubber Track Design
602 Views, 16 Replies
01-09-2013 07:17 PM
Trying to model a track but i have it in more of a triangular orientation then an ovel like this sample picture. Any advice on how to pattern the tread and inner lug around any shape i desire? I have tried making an extrusion on one of the flat faces and then patterning it around but it keeps the lug in the same orientation and does not follow the contour nicely. Any advice for me
Valued Contributor
streharg
Message 2 of 17 (590 Views)
Re: Rubber Track Design
01-09-2013 11:36 PM in reply to: mklassen78
You can do rectangular pattern in part enviroment along choosen curve, and set orientation to direction1. This should work.
I hope that's what you're looking for.
Greg
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
JDMather
Message 3 of 17 (572 Views)
01-10-2013 04:42 AM in reply to: mklassen78
mklassen78 wrote:
Trying to model a track but i have it in more of a triangular orientation . Any advice for me?
See this document pg 16
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
mklassen78
Message 4 of 17 (520 Views)
01-10-2013 06:19 PM in reply to: JDMather
Thank you for your replies! JDMather that does work to pattern around and i can get it to follow the contour i want but it leaves a gap between the "treads" as it is patterned around a curve. It does not keep tangent. Any solution to that?
JDMather
Message 5 of 17 (517 Views)
01-10-2013 06:55 PM in reply to: mklassen78
Attach your ipt file here.
Member
mklassen78
Message 6 of 17 (507 Views)
01-10-2013 08:21 PM in reply to: mklassen78
Hope this helps more
JDMather
Message 7 of 17 (492 Views)
01-11-2013 04:47 AM in reply to: mklassen78
I don't see a pattern in the file you attached?
When I attach my solution the sketch for the tread will be on the XY plane.
The extrusion for the belt will initially be a surface body and then Thicken after the Pattern of the treads.
Member
mklassen78
Message 8 of 17 (477 Views)
01-11-2013 08:07 AM in reply to: mklassen78
That is why im on this forum, It will not allow me to pattern and keep tangency, It just gives an error. The lugs i want to pattern are in the file though.
JDMather
Message 9 of 17 (473 Views)
01-11-2013 08:33 AM in reply to: mklassen78
mklassen78 wrote:
.... It just gives an error.
Post screen shot of error.
JDMather
Message 10 of 17 (466 Views)
01-11-2013 09:07 AM in reply to: JDMather
I experimented with this one a bit more.
It is going to be a bit more work than I originally thought.
Because the tread cleats bend around the curves - my attempt would be with patterned-trimmed surfaces, thicken and trim again.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
