how can i use/activate routed systems in inventor pro 2014 or is this option disabled on the student version?
Best regards
Stefan Jung
Solved by JDMather. Go to Solution.
Student version is fully functional?
Have you gone through the Routed Systems tutorials?
Has your instructor demonstrated Routed Systems?
You must be in an assembly.
Then go to Environments tab.
You should see the Routed Systems tools.
Screen cap from student license Inventor Pro
Not sure if it's there in Student version or not... check this:
Go to Tools\Add Ins. Do you see it in there? If yes, click the boxes for Loaded and Load Automatically.
This is from 2013 but should be the same in 2014.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
@cbenner
the add ins are both aktivated
@JDMather
I was in an assembly of the routed sytems tutorial and it shows the icon only in grey.
I think that the student version is fully functional.
The image I posted is of the Student version, so it looks like you did not get Inventor installed correctly as even Inventor Studio is grayed out in the image you posted.
Did you install with anti-virus and UAC turned off?
(if you are not sure - search Google on how to turn off UAC).
I would try a Repair Install first (with UAC turned off) and install Update 1, reboot the computer and see if it now works.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21503391&linkID=9242019
If that doesn't work - post back for Clean Uninstall instructions (you can only activate your license twice, so this will be a last resort effort if needed
