Hy. I wish to use rotated centerlines for my drawing as the red lines .. any ideas how ?
Solved by blair. Go to Solution.
I guess two ways, use the Bisector Center Line, this will produce a curved center line between your inner and outer curved sides. Depending on the part, you may be able to use the circular center point command (requires a center-point).
