An interesting problem for all you inventor users.
I have a design where a tube/pipe requires a series of holes at a specific dia and triangular pitch is required to be modeled.
If one can imagine a flat piece of sheet steel ie standard perforated sheet which is then rolled to form a pipe/tube to a specific dia then this is what is required.
Is it possible to model this in inventor say as a flat sheet with given thickness and a specific no of holes at a given pitch, this then to be rolled,obviously the development of the sheet to be correct for the pipe od.ie 3.142 x dia.
Is there a function in inventor to enable this,the alternative being a very long winded method of modeling the pipe and then adding holes.
Regards
Solved by IgorMir. Go to Solution.
Solved by JDMather. Go to Solution.
Solved by mpatchus. Go to Solution.
Try using the UNFOLD and FOLD features like shown here.
Probably more than one way to do this, but this is one method.
Contour Flange to model pipe.
Unfold
Hole by some method or other, (Hole, Cut, Punch, Extrude).
(Pattern if appropriate).
Refold
Flat Pattern
Attach your attempt here.
I see Mike beat me to the answer and even modeled the example.
How will the holes be made in the real world?
If it matters, are you aware that they can be circular in the flat or in the bent part, but not both?
Mike
In answer to your question how will the holes be made in the real world.
What happens is that the section of pipe is centre punched using a 2d draughted template ,the template is then wrapped around the pipe centrepunched on the centrelines of the hole and then hand drilled,a time consuming process considering that sometimes as many as 500 holes are required,but its to date the best and easiest method yet.
One question from your solution ! wher can i find the folded model command?
Regards
Martin
You have to start the part as a SHEET METAL part, or convert an existing part to a sheet metal part to gain access to the Fold & Unfold tools.
Hi Martin,
Here is an example of the part which is good for laser cutting in flat state. Please see the attached. Once rolled up there should be no need to manually re-drill the holes.
For the triangular pitch for holes some more work is needed on the part. I will try to look into it later on.
Best Regards,
Igor.
