hello,
I am having PDS Ultimate 2012 and working on inventor. when i open a file or open a new template ribbon freezes means menu bar doesn't work properly,if i change the ribbon appearance it doesn't update also i cannot switch between the menu bar tabs and if i turn on the visibility of the datum planes it doesn't show on the screen.But when i refresh the windows everything works sometimes. i have installed SP1 and even repaired inventor. Please suggest to resolve this issue.
Thanks.
System Config:
OS Name Microsoft Windows 7 Professional
System Manufacturer LENOVO
System Model 20079
System Type x64-based PC
Processor Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz, 2300 Mhz, 2 Core(s), 4 Logical Processor(s)
Name AMD Radeon HD 6370M
Adapter Type ATI display adapter (0x68E4), ATI Technologies Inc. compatible
Adapter Description AMD Radeon HD 6370M
Adapter RAM 1.00 GB
Are you on the latest driver for your graphics card?
hello,
i have updated the driver but problem still remain same. i have anothe machine with exactly same configuration but its working fine.
