Inventor Forum
Revision Table
2 REPLIES 2
274 Views, 2 Replies
Revision Table
Is it possible to make a revision table with lines that disapear against the
background, or no lines at al?
2 REPLIES 2
lee.bo.wang
Hi Hans,
i don't know whether you used the default sheet colour, i just use the default sheet setting as one example .
1. Tools-->ducument setting..sheet tab,-->click "sheet" -->define custom colors-->get the sheet color RGB parameter(237,237,214)
2.go to style editor-->new a layer-->set the color to RGB(237,237,214)
3.then you can change the Revision Table layer to created in step 2 under "object default".
4.also you should change Note Text corlor (uncheck the automatic,or new one text style) used in Revision Table, otherwise, the text in revision table are invisible.
Hope this is useful. Thanks,
Lee
Autodesk Inventor QA,
Hi Lee,
Line management like in Excel would be the
best option for me because some of the exterior lines cover part
of the Title Block. The interior lines I have set to white, wich is not
invisible but will not print.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Hi
Hans, i don't know whether you used the default sheet colour, i just use the
default sheet setting as one example . 1. Tools-->ducument setting..sheet
RGB parameter(237,237,214) 2.go to style editor-->new a layer-->set the
color to RGB(237,237,214) 3.then you can change the Revision Table layer to
created in step 2 under "object default". 4.also you should change Note Text
otherwise, the text in revision table are invisible. Hope this is useful.
Thanks, Lee Autodesk Inventor QA,
