Inventor Forum
Rev properties (an easy one for monday)
5 REPLIES 5
286 Views, 5 Replies
I inserted a revision table into a idw (and associated markers). It is pretty easy to choose the fields for the table, but where are the properties that populate this table? I checked the ipropeties of the drawing and model, but not there. I just want to use rev #, description, By, and date. The rev # and date was automatic, but the "description" and "by" shows "value". Where are they hiding?
5 REPLIES 5
Double click on one
Dave Hoder
Product Design
Engineer
idX Seattle
href="http://www.idxcorporation.com">www.idxcorporation.com
That's too easy.
Rev. Block not very usefull if You need
to add additional revisions at a later date.
Joe
Joemang, what do you mean..."Rev. Block not very usefull if You need to add additional revisions at a later date" ?? all you do is RMB your rev 1 chart, and select 'add row', then it will add your rev 2 row. did i miss what you were syaing in your statement? -Joe
jmartzig Thanks for setting me straight.
You are right RMB in rev. no. block did the trick.
If You RMB in any other area and pick add row
the whole block get's replaced
Again Thanks Joe
