Inventor Forum
Restriction of a constraint.
4 REPLIES 4
sgt.borup
779 Views, 4 Replies
Hello Inventor users ! I see myself as a quite experienced user in autodesk inventor, and i have used it regularly the last couple of years, but one thing that has been buggering me the last couple of weeks, is regarding constraints.
is it possible to restrict a constrains movement along an axis (S) at some sort?, for example a cylindrical object with a metal rod going through it, then limit the cylindrical object to only make it able to move for example 10 centimetres (ΔS) ?
4 REPLIES 4
in reply to: sgt.borup
they indroduced this facility into 2011, which version are you using?
sgt.borup
Im using Inventor 2008, could you supply possibly supply me with screenshots ? since my school have 2011 🙂
as you can see, there is a new button >> which extends the contraint box
you now have the limits tab where you can select your maximum and minimum values, the 'use offset as restin position' is a kind of snap button.
so align along your centre axis as normal, then add a face constraint using the 2 additional max and min values to limit your movement.
For Inventor 2008, you will want to use this:
http://teknigroup.com/tutorials/Inventor/restrictiveTransConstraint.html
