I made a few changes to our Standard template. To test out the changes I made sketches, faces, flanges etc.
Unfortunately, when we create a new part, the first sketch starts at Sketch17, the first face is Face11, the first flange is Flange4, etc. Also looking at my part parameters, I start at d53. (See attached picture)
Is there a way to reset these counts back to 1?
*I know I can start a fresh template using the CTRL+SHIFT + new part, but this erases all changes to the template I have made.*
Try taking this template and doing a copy save as template. Then create these test sketches using this newly copied template. These items should reset themselves.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I should have mentioned that in my post.
Doing a 'Save Copy as Template', and using that new template to create a sketch makes no difference.
I still start at Sketch17.
What version are you running? This has come up a few times on this forum. I haven't seen a thread that has a slam dunk solution. This is a weird occurrence and usually starting new resets everything.
I also noticed that in your image you are creating a sheet metal part. Does your template start with sheet metal functionality or do you start with a very bare bones template. Similar to what you get out of the box.
I am going to go out on a limb and say, because you start this template out as a sheet metal (which is fine) it is locking in the sketch numbers in at what they were last saved as. Now, if you have done this procedure before and this is the first time this has happened to you, then that just blows a hole in my theory.
This is just a guess on my part. Someone else can chime in and either confirm what I am saying or tell me I am completely all wet.
Mike,
Still only being on 2012 are you saying that this might be an issue that needs to be addressed by Autodesk?
Mike,
Sorry it took me so long to get back to you. I left early yesterday and didn't have time until now to check this out.
Here is what I discovered. With our default templates, if I start a brand new part it starts out with sketch3 and extrusion1 everytime. I did as you suggested and opened up our part template and did a saves as copy template and when I used that part template, I got the same results. Sketch3 with extrusion1.
So I guess the conclusion is in 2012 these do reset themselves.
This has been an issue sine r4 when I started on Inventor. I have just gotten used to all my parts starting at sketch 7. It has been talked about a fair bit over the years, and like you say, there isn't a solution, other than creating a template from scratch.
I see your point. I said what I said because it was always starting with sketch3 and extrusion1. Not sure why it starts with sketch3.
I have posted an idea to address this discrepancy.
Thanks for looking into this Scott & Mike.
Hopefully this is something that can be resolved down the line at some point.
~Jonathan
Jonathan,
No problem. Sorry there is not a better answer for you.
Feel free to go to the idea link I provided in my last posting and cast your kudo vote for this.
I just asked for some comments on the idea station thread. Please go there to comment.
We are now gravitating towards idea station for new idea discussions. We are actively monitoring it for future releases.
