Inventor General Discussion
New Member
ttruman
Message 1 of 2 (298 Views)
Accepted Solution
Reset revision block data
298 Views, 1 Replies
10-19-2012 09:20 AM
We frequently will create a new part and drawing based on an existing drawing to save time recreating views and re-dimensioning the entire drawing. This is done by using Design Assistant to copy the idw and ipt file to a new name.
The only problem we have experienced with this workflow is that the revision history for the old drawing is maintained in the new file, and there doesnt seem to be a way to reset it. This also causes us a problem if a drawing needs to be changed from numeric to letter indication of revision level.
Does anyone know of a way to reset the revision history so that a new table can be started from scratch?
*Expert Elite*
Curtis_Waguespack
Message 2 of 2 (289 Views)
Re: Reset revision block data
10-19-2012 10:15 AM in reply to: ttruman
Hi ttruman,
Unless I'm misunderstanding, you'll want to delete the revision table and revision tags from the drawing, and then place a new revision block. That will let you choose the starting revision number, etc. again.
Also be aware that older versions of Inventor had limitations in this area, but I don't recall when the changes were made (Inventor 2009 maybe?).
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
