I am working on a drawing using Inventor and it keeps closing on me. I have noticed that in the model history if I try and right click on the problematic item to delete it a red box shows up with Repeat Seperator next to it. If I try and do anything with this option my drawing closes. Also the Repeat Seperator appears on the part level, but only in the exploded presentation of the part.There is no issue with the actual assembly. What do I do?
Well, knowing this is a three year old post, welcome to the forum I guess.
I found this after a co-worker asked me what this was?
Never seen it before I told him. When I asked him what he did just prior knowing that the "Repeat..." is for just that, repeat the command you just executed. He said he had done a copy design in Vault and called up the drawing. Then RC'd on the model in the drawing and got what is shown above. Typically my experiance has been when no previous command has been initiated, the repeat at the top of the RC menu is greyed out.
Anyone else seen this and have an explaination?
I know he has carried on and not experienced any hickups.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
