Inventor Forum
Render JT files
3 REPLIES 3
566 Views, 3 Replies
Render JT files
Hello everybody,
I opened a .JT files without issues, it shows the model as it suppose to do and also without erros.
When I try render it, it dissapears.
The same happens when exporting to STEP.
And it is also not possible to make a section view.
I have the feeling that is has to do with the fact that JT files are use for visualisation. Something with nodes?
Is there a way to convert the JT file that it acts as a normal Inventor file?
Thanks in advance.
Cheers,
Maarten
3 REPLIES 3
mcgyvr
can you get the part in another format? step/iges?
No, I can only get it in .JT.
ChrisMitchell01
Maarten,
See if you can get a JT file which includes the BREP info - you likely only have JT that contains the tesselated/mesh data.
They will likely need to export the JT file again.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
