Inventor Forum
Renaming sheets in a multi-sheet IDW....
5 REPLIES 5
andrew.cox
1752 Views, 5 Replies
Is there any easy way to have sheet name automatically pull the "description" iProperty from the part that is on the sheet?  It can be very handy in a multi-sheet drawing for each sheet to have a descripive name in the browser, but the only way to do this (that I know of) is to manually change it.
Andrew
5 REPLIES 5
Hi andrew.cox,
Here's an iLogic rule to do this. Note that description might not write to the sheet name correctly if it has characters such as commas in it.
I hope this helps.
Curtis
Dim oSheets As Sheets
oSheets = ThisDoc.Document.sheets
Dim oSheet As Sheet
For Each oSheet In oSheets
	oSheet.activate
	Dim oDrawingView As DrawingView
	oDrawingView = oSheet.DrawingViews(1)
	oModelName = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	oDesc = iProperties.Value(oModelName, "Project", "Description")
	oSheet.Name =  oDesc
Next
Hi Curtis,
Thanks for this info!  However, I have not even used iLogic, so I don't know what to do with this.  Any chance you could point me towards a good tutorial, or provide me instructions yourself?
Cheers,
Andrew
Hi andrew.cox,
This should cover it:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Hi Curtis,
I'm having some trouble with the code you supplied.  When I enter in into the "rule", I get this error....
I cut-and-paste the code exactly as you had it in your previous post.  Any thoughts?
Andrew
Hi andrew.cox,
Most likely there is an issue with a line wrap due to this forums formatting, or something like that. Attached is the rule in a text file, you can copy and paste from it.
If you see the same results post back.
I hope this helps.
Curtis
