Inventor Forum
Remove section line
3 REPLIES 3
luiww
7024 Views, 3 Replies
Remove section line
I tried to place a round section shape on the o'ring but does not want to show the section plane.  Wonder if there is a direct mean or workaround approach.  Attached is the graphics.
3 REPLIES 3
admaiora
in reply to: luiww
You can do something.
Select your section line, right click  > "Show entire line"
Then for more change, select your section line, right click> "Edit view annotation style"> and choose  a "lighter" standard section line  and make other changes
If you want to make invisible ALL, you can go in Annotate> Edit Layers > click the light bulb for "Section Line" (then make  a little zooming to note the change)
note: you have to consider that if you quit the visibility for section line layers, all the section lines in that drawing will not be visible, you can create other layers and change layers for objects.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
luiww
in reply to: admaiora
Thanks for the help. It solve my problem.
onkaralchemist
in reply to: luiww
How to add section lines in section view in inventor
