Solved by rickduley. Go to Solution.
Solved by JDMather. Go to Solution.
To the right you should see links on Need installation help?
You will have to find the information on doing a Clean Uninstall before attempting to re-install.
Post back if you can't find the document.
Rick,
Welcome to the forum.
Please send us an update after you have performed:
Thank you.
@mcgyvr wrote:
As best as I have been able I have done a clean uninstall of Autodesk Inventor but I am not getting any closer to an Install.
Windows Uninstall shows no trace of Autodesk.
AI finds Autodesk files I cannot find even with Agent Ransack. I can install three large ancillary files, but not inventor itself. I am in touch with the people from Autodesk Education Downloads who provided me with this login. Infortunately, they are still looking for a way to facilitate my re-installation.
I will get back to you on this, Bob, but in the meantime I am wide open to suggestions as to how to get Install to work.
I have escaped the re-installation problem by installing Inventor 2015. Some days after I had done so I recevied an email from Autodesk Education with this link.
I note that it refers to the 2013 version of Language Pack, so I haven't taken their advice. I'll let lying dogs sleep as they say downunder. While AI15 is working, I do not want to run the risk of raising more problems.
