Here is the problem I try to solve, probably not being familiar enough to Inventor yet.
In my assembly, 2 different sub-assemblies (let's say A and B) are constrained to move along 2 different rails perpendicular to one another.
I'd like to link the position of B as a function of the position of A, but cannot do it in "realtime".
Actually, I tried to use fx parameters to link B to A, but couldn't find the way to update those parameters so that B would change position as soon as I drag A along its rail with my mouse.
Any idea?
Thanks a lot.
Thank you for the answer Michael.
But I've not been clear enough obviously.
So, in detail :
Two straight rails Rx and Ry are fastened to a reference solid S. Ry is perpendicular to Rx and S doesn't move.
Sub assembly A is moving on rail Rx. Let's call x its position on this rail. (Actually x is the distance value of a constraint between A and S).
Sub assembly B is moving on rail Ry. Let's call y its position on this rail. (Actually y is the distance value of a constraint between B and S).
A and B are mobile (neither x nor y will be constant), so that I can't define a constant distance between A and B and apply it as a constraint value.
Actually, I'm looking for a way to set y as a function of x ( y=f(x) ), so as to see B moving along its rail Ry while I drag A whith the mouse along its rail Rx.
Any idea again?
Can you attach the assembly here (or a simplified representative assembly)?
Do you have Inventor Professional with Dymamic Simulation?
See the attachement as an example (TestAssembly.iam)
Both black solids move independently, but I'd like their postions to be linked in some kind of y=f(x) function.
Thanks Michael.
Your attachment actually doesn't show up.
But I think you didn't understand what I'm looking for, since if I follow your indication, the positions of both solids are not linked to each other by any mathematical relationship, nor updated in realtime.
I don't know of anyway to do this outside of Dynamic Simulation (edit: Due to the free drag requirement. If you can handle manually inputing an x value then Inventor can certainly drive a y value using an f(x)). Can you answer JD's question (do you have Inventor Professional)?
A relationship between your X and Y can easily be set and driven by usingthe DRIVE CONSTRAINT function.
If you can establish a "hidden" mechanical relationship, you might be able to drag you X and have the Y move in "real time" - if for instance you can create some hidden parts (tracks with tangent constraints, cams, etc...) Those parts can be undisplayed during the drag.
Otherwise as mentioned above, you'll need other tools.
