Since i have installed SP 1 Ray Tracing doesn't work anymore.
The Icon is grey !!!
Does anybody else have this problem?
Solved by alessandro.gasso. Go to Solution.
no mine works here
try going to tools>application options>apperance settings
and see if its selected in there
DarrenP
The Ray tracing is available just in Realistic and Monochrome visual styles.
Is that your case?
Thanks and regards,
Alessandro
I can only combine the monochrome with the Ray Tracing.
Not the Realistic with the Ray Tracing.
Who can help me, i din't had this problem before i installed the SP1
If you go in menu Tools > Options > Application Options > Hardware tab, which is the current Graphic Setting?
The Realistic style + Ray tracing is available just if the setting is Performance or Quality.
If this is not the current setting, change it and restart Inventor.
I hope it helps.
Kind regards,
Alessandro
This solved my problem. The settings where wrong although i didn't change them. Is it possible the installation of SP1 changed the settings?
I’m glad I could be helpful.
In general this should not happen, but, if this was your case, and you are using a Microsoft WHQL certified Direct3D graphics card, I’d suggest you to check if there is a newer Microsoft WHQL certified driver for your graphic card on the manufacturer website.
Kind regards,
Alessandro
