Inventor Forum
Radius Extrusion Possible or not?
15 REPLIES 15
Message 1 of 16
1790 Views, 15 Replies
Here’s the dilemma.
So I have this corner sample I need to create.
Imagine if you will a 6” x 6” corner of 1-1/8” thick Baltic Birch plywood.
The corner has a 3-1/4” radius.
The profile is a 30 degree knife edge with a ¼” left at the top.
0.04” HPL top sheet and 0.04” backer.
If I create the plywood in an assembly to show realism, how do I get the profile to wrap correctly around the radius?
If I sketch the profile onto the assemble and extrude it, the profile just runs off the end.
You don’t have the option of sweeping an assembly so that’s not an option either.
Any advice would be appreciated.
Thank you.
So in the image you see the Mitered corner version. I want to achieve a radius corner but have the profile flow with the radius.
15 REPLIES 15
Message 2 of 16
mrattray
Can you post some examples?
Files showing your best attempts and some screen shots to show the end result you're after would be helpful.
Mike (not Matt) Rattray
Message 4 of 16
JDMather
Thank you.
Multi-body solids and push out the assembly.
What release of Inventor are you using?
Message 5 of 16
in reply to: JDMather
2012
Message 6 of 16
JDMather
>Imagine if you will....
The cool thing about CAD - no word imagination descriptions needed. (In fact, isn't that the very purpose of CAD?)
Pictures, and better yet - your best 3D modeling attempt will go a long ways further than a lot of words.
Attach your files here.
Message 7 of 16
Message 8 of 16
JDMather
This is like pulling teeth. That image is way too small.
Go to the Windows Globe icon in lower left corner of your screen.
Start typing Snipp...
and click on Snipping Tool.
Capture image of only the  geometry on your screen (we are already familiar with the Inventor interface).
Snipping Tool.png or better yet - attach your *.ipt files here.
Message 9 of 16
Hi JDMather,
Just to avoid confusion I'll mention that it looks like the OP might be using Windows XP, and therefore is not likely to have the Snipping Tool available.
I hope this helps.
Curtis
Message 10 of 16
WHolzwarth
Something like that?
Walter
Walter Holzwarth
Message 11 of 16
4donwan4
Just from the imformation here and viewing the screen shots. I would think a 2D profile with a 3D Sketch could sweep the initial shape. You can do this in an assembly file as long as you are within the part edit environment. Create the part within the assembly and if needed project points from other part file to create the 3D Sweep. Again just my initial thoughts.
Don
Message 12 of 16
mrattray
This is a perfect application for multi-body solids, as JD suggested at the start of the thread. Any other method is going to be significantly more work.
Message 13 of 16
WHolzwarth
in reply to: mrattray
Have you tried it, Mike?
IMO, each and every body needs to be selected for the sweep.
Walter
Walter Holzwarth
Message 14 of 16
mrattray
in reply to: WHolzwarth
Here's a quick example:
Edit: I forgot to mention: I can't open any of the parts in this thread because I'm still on 2013, so I'm just going by the pictures that the OP posted.
Message 15 of 16
JDMather
Having read the other thread by this OP, I'm not really sure of the design intent or best approach.
I am fairly sure though, that the OP is doing way too much work.  (see post #24
http://forums.autodesk.com/t5/Inventor-General/Sweep-Cut-Assembly/td-p/4901946/page/3
Message 16 of 16
mrattray
Wow!  You can say that again, JD!
