Inventor Forum
RIBBON ISSUE WITH IPART!
4 REPLIES 4
LOONYLEN
269 Views, 4 Replies
Gentlemen,
I have an issue with IV2012 where the ribbon category widths shrink and you cant see whats in each category.
Is there a hot fix for this that I dont know about?
I've attached a screen capture for better clarity.
Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
4 REPLIES 4
skyngu
in reply to: LOONYLEN
This issue happens on my machine randomly. it is not only related to ipart.
I hope autodesk inventor can fix it soon.
Autodesk Inventor Professional 2019
blair
in reply to: skyngu
Make sure you are on the latest Microsoft certified graphics drivers. The stock drivers that ship with OEM machines tend to be some of the first release drivers. Also check that you are running Windows Area and try switching between Quality and Performance within the Inventor Applications/Hardware tab.
This seems to clear up a number of display/graphics card issues.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
LOONYLEN
in reply to: skyngu
I have found a solution to this problem.
Although I do not know if this solution will prevent the ribbon from doing this again or not, but here is the solution.
Right click on the ribbon.
click on show panel titles.
Fini
Version 2009, w/SP1
skyngu
i am sure that the hardware and software meet standard of autodesk inventor. i have not found pattern of this issue. it hapeens randomly. however, i dont think that is correct solution of this issue.
thanks.
