I was thinking about a way to visualize machined surfaces on cast parts and
weldments. The thought is, by changing the color of the surfaces of a part
through the properties. Then, doing some machining by extruding some shape
through the part (cut), and the orginal color of the part reappears. Much
like painting a cast before machining.
Now the question is, is there an easy way to select all the surfaces of a
part to change the color at once? (I know I can keep the shift-key pressed
and select all the surfaces, but the I have click every single one)
