Inventor Forum
Question about presentation
3 REPLIES 3
BeKirra
276 Views, 3 Replies
How to make a custom "view" to associate with a "position"?
Thanks for your help.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
3 REPLIES 3
rdyson
in reply to: BeKirra
In the ipn RMB "save camera"
In the idw / dwg base view orientation "saved camera"
PDSU 2016
BeKirra
in reply to: rdyson
Sorry, I did not clearly state the question.
It is about the presentation in IAM envrionment, not in IDW.
X² + Y² = C²
admaiora
Hi Bekirra,
you can't normally.
But you can with the power of iLogic.
I have upload this video for you, hope that it can helps you.
Here the sample code:
myview = ThisApplication.ActiveDocument.ComponentDefinition
If myview.RepresentationsManager.ActivePositionalRepresentation.Name = "UP" Then
	myview.RepresentationsManager.DesignViewRepresentations.Item("UP").activate
ElseIf myview.RepresentationsManager.ActivePositionalRepresentation.Name = "DOWN" Then
	myview.RepresentationsManager.DesignViewRepresentations.Item("DOWN").activate
End If
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
