Inventor Forum
Question about Trig functions in Paremeters
1 REPLY 1
cwilko
1094 Views, 1 Reply
Hello All
Lately it seems the only questions I have to ask is to do Parametric Trig equations.
So here we go again.
I am creating an equation driven part with a few Trig eqautions. (Not that difficult until now)
One equation I need to input requires the Trig function Cotangent (cot).
eg. cot (x deg / n ul) with the unit type set at (ul)
This syntax does not work.
But when I rewrite the equation as 1 ul / tan (x deg / n ul) or tan (x deg / n ul)^-1 ul I get the result that cot should give me.
Does Inventor not support the Cotangent, Secant or Cosecant functions?
Or am I just misrepresenting the syntax description?
Thanks Clint
Inventor 2012 Professional
1 REPLY 1
sam_m
in reply to: cwilko
list of valid functions (in "References" -> "Use formulas and equations" -> "Functions")
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0733-Design_O733/0736-Paramete73...
no cot, so guess you're stuck with 1/tan
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
