Please help, how can I put a dimension on circullar centerline?
When I really struggle I do a sketch on the view.
Click the view first and hit S. You can now progect geometry from the view and draw in a new line.Finish Sketch. RMB the sketch in the browser and change the properties to make it more visible. Then pull a dimension off your sketch line.
Are you saying you cannot select the centerline itself with the dimension command?
I have no problem adding a dimension to a circular centerline.
Is the centerline a full circle?
You can right-click after selecting the centerline with the dimension command to get options for dimension type, radius or diameter.
Please explain your problem a bit more.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
yes, it is full circule and I choose dimension tool and click circle it sees one but no dimension appear, centerline was made by centerline button
Ok, so you're not seeing the same as in this video:
Can you post the files (idw + ipt)?
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
hi furnaux,
did you mean how to add dimension in the circle like this?
try this one, Change your squence procedure.
create hole after fold your part.
