I`m not sure if anyone had this problem. I do have a part with decal feature. I tried to publish it to my library, and I`m getting a error see below.
Is there anithing I can do to avoid this? Is there any way to break a link with the image or other way around?
Solved by -niels-. Go to Solution.
I've never had to publish a part with decal to the content center, but did you insert the image with the "link" checkbox checked or unchecked?
I believe it's checked by default when you insert images, so try without having it checked.
Hope it helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Great! It worked ! Thank you.
