I'm having problem in publishing this piece.
The items in blue should always be selected, but when published in error in creating the piece.
In Inventor 2012, this feature worked correctly, however in 2013, could find no solution.
if someone can help me, I'll be grateful.
Ivanildo
It looks like you have a column in the ipart you are publishing that would allow Inventor to create 2 parts with the same filename. Content Center will kick out an error if that is the case. It could be something as simple as a typo that put identical values in two places. Hard to say for sure without seeing the family table itself. But looks for something like that.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
